Live Streaming Camera
Pro Live on Air
Highlights Overview.
4K30
1/1.3″
CMOS
Wireless Live Streaming
Multi-Platform Streaming
24/7
Streaming
App + Desktop
Control
Plug and Play
VenusLiv Air redefines compact streaming cameras with cinematic 4K image quality powered by a large 1/1.3″ CMOS sensor and a custom F1.05 lens. Whether you're live streaming, podcasting, or creating content from your studio or home, it delivers true-to-life colors and exceptional clarity — even in low light. Built-in AI tuning allows even first-time streamers to achieve professional-looking results with ease. From green screen and image overlay to skin beauty and color correction magic, VenusLiv Air gives you full creative control. With flexible streaming options, intuitive app and desktop control, and reliable 24/7 performance, it's built to power your stream — anytime, anywhere.
Cinematic
4K Image Quality
Powered by
1/1.3″ CMOS
F1.05
Custom Lens
Craft an Immersive Streaming Space
CMOS
1/1.3″
Lens
F1.05
Effective Pixels
50 MP
VenusLiv Air combines an F1.05 large-aperture integrated custom lens with a 1/1.3″ high-performance CMOS and a 50-megapixel sensor to deliver enhanced video quality, rich contrast, and soft background blur, making it easy to create expressive moods for live streaming.
True-to-Life Color Reproduction
Built on a database of tens of thousands of real streaming scenes, our image quality engineers have carefully analyzed and calibrated various lighting and color conditions. With this foundation, VenusLiv Air applies an advanced color restoration algorithm that precisely reproduces true-to-life colors in any streaming environment.
Stay Crisp Even in Low Light
Backed by a 1/1.3″ CMOS sensor and an F1.05 large-aperture lens, VenusLiv Air delivers clean, noise-free visuals whether you're live streaming in a dark room or under soft lighting.
AI Tuning
AI Tuning
AI Tuning
AI Tuning
AI Tuning
AI Tuning
AI Tuning
Even Beginners Get
Stunning Shots
With years of live streaming experience and extensive real-world data, VenusLiv Air comes with our self-developed AE and AWB algorithms that intelligently analyze lighting conditions and fine-tune image parameters in real time. No camera expertise required — anyone can achieve professional-grade image quality with ease.
AI Tuning OFF
AI Tuning ON
Ready-to-Use Multi-Scene Preset
Just Tap and Shoot
You can also configure settings manually, save up to 20 custom presets for different shooting scenarios and switch between them instantly with a single tap.
Podcasting
Lifestyle Streaming
Live Commerce
Plug and Play
4K30 UVC Streaming
Just plug into your computer and go live via a USB 3.0 cable.
No capture card required, simple and convenient.
HDMI Output
Connect to a switcher via HDMI for professional multi-camera workflows,
or directly output the signal for real-time monitoring.
4K Wireless
Live Streaming
Go live in 4K — no computer required. Instantly stream to Facebook, YouTube, or Twitch with one tap: just scan the QR code and log in with your account credentials.
Want to stream to a custom platform via SRT or RTMP? Simply scan the QR code and enter the streaming URL and key.
No matter the platform, all settings are securely synced to the camera through the cloud. No need to log in again — just power on and go live.
*Video resolution is subject to different platform limitations.
Stream to two platforms simultaneously without a computer. Expand your audience effortlessly, anytime, anywhere.
App + Desktop Control [1]
Now you have full access to monitor your live feed and control your camera from a distance by connecting your mobile device or PC to the VenusLiv Air — anytime.
HollyCam [1] (Mobile App)
Real-time camera monitoring; Recording; Device control (Focus and zoom control; Scene parameter adjustment; Color tuning; Exposure lock) etc.
Download
HollyStudio [2] (PC Software)
Green screen; Image overlay; Skin beauty; Real-time camera monitoring; Recording; Device control (Color correction magic, Focus and zoom control; Scene parameter adjustment; Color tuning; Exposure lock) etc.
Download
High-Quality Audio
Fast, Stable Connection
VenusLiv Air body has a dedicated USB-C digital port, allowing you to easily connect Lark series wireless microphones for crystal-clear, high-fidelity audio.
Powerful Heat Dissipation
Built for 24/7 Streaming
Unlike typical smartphone or DSLR setups that often overheat or suffer from unstable live feeds, VenusLiv Air features an advanced air-cooling system and ample internal space for heat dissipation, providing smooth and uninterrupted streaming experience.
Professional Live Streaming
Made Easy
Paired with the HollyStudio [1] PC software, VenusLiv Air unlocks a range of advanced live streaming features — without the need for complex setup. Get started quickly and deliver stunning live visuals with ease.
Green Screen
Our self-developed green screen keying technology outperforms conventional algorithms found on mainstream streaming platforms. With just one tap, you get clean, professional-grade keying — even around tricky areas like individual hair strands and intricate edges. It's smart, fast, and incredibly easy to use.
Color Correction Magic
Enjoy professional-grade full-spectrum RGB control and targeted color tuning, allowing for quick adjustments to specific colors. Simply pick a color, then fine-tune its hue, brightness, and saturation. In just three seconds, you can dial in the perfect look — delivering vibrant, professional-grade visuals that make your livestreams stand out. You can also access this feature through the HollyCam mobile app.
Image Overlay
Easily enhance your live streaming scenes by adding eye-catching overlays, animations, and images directly from the built-in library or by uploading your own custom contents.
Skin Beauty
Powered by Hollyland's advanced beauty algorithm, VenusLiv Air intelligently detects your face and skin, separates you from the background, and enhances your appearance with smart skin brightening, texture smoothing, and tone correction.
Flip Screen for
Instant Composition Preview
VenusLiv Air supports both horizontal and vertical live streaming. Its built-in 3″ touchscreen flips 180°, making it easy to check your framing in real time — whether you're setting up or going live.
4K UHD Recording Beyond Live Streaming
More than just live streaming. One-tap 4K recording lets you create, edit, and share your content with unmatched ease.
Your Package List
VenusLiv Air x 1
12V / 2A Power Adapter x 1
USB-C to USB-A Cable (10FT/3M) x 1
Lens Cap x 1
Quick Guide x 1
Compliance Information Card x 1
Warranty Card x 1
Upgrade Your Setup.
Lens Hood
Weight
660g (+/-100g) (Camera body only)
Dimensions
L*W*H: 134*97*101 (+/-5mm)
Focus
Hybrid autofocus (Phase + Contrast), supports continuous focus
CMOS
1/1.3-Inch
Effective Pixels
5000W
Lens
  • 4K optical fixed-focus lens
  • Equivalent focal length 25mm
  • Aperture F1.05 (Equivalent F3.6)
  • 4x digital zoom
  • FOV:
    Diagonal: 84°
    Horizontal: 70°
    Vertical: 55°
Ports
  • DC IN: 5.5*2.1mm
  • HDMI OUT: HDMI 2.0
  • USB-C: USB 3.0
  • USB-C: Digital audio
  • 3.5mm jack
  • SD card slot
  • RJ45 network port
Buttons
  • Power button
  • REC button
Video Output Formats
  • Record
    3840*2160/ 2160*3840 (30 fps)
    1920*1080/ 1080*1920 (30 fps)
    1280*720/720*1280 (30 fps)
  • UVC (MJPEG)
    3840*2160 (30 fps)
    1920*1080 (30 fps)
  • UVC (YUY2)
    1920*1080 (30/60 fps)
  • UVC (NV12)
    3840*2160 (30 fps)
  • HDMI output
    1920*1080 (60Hz)
  • RTMP output
    3840*2160 (30 fps)
    1920*1080 (30 fps)
    1280*720 (30 fps)
Touchscreen
3.0-Inch TFT, 480p
Audio Input
UAC wireless MIC, 3.5mm analog MIC / LINE IN
Audio Output
HDMI, UAC digital audio output
WIFI+BT
Dual-Band 2.4G + 5G Wi-Fi, Bluetooth 5.0
Power Consumption
MAX 10W
DC Input Voltage
12V 2A
Operating Temperature
-10 °C to 40 °C
Storage Temperature
-10 °C to 60 °C
Note:
 1.
The HollyCam App has been officially renamed to HollyCam. All core features, data storage, and user experience remain unchanged.Users can continue using the app as usual, and no additional actions are required. The desktop icon will automatically update to the new logo.
 2.
The Mac version of HollyStudio supports only basic parameter adjustments. Advanced features such as green screen, image overlay, skin beauty, and color correction magic are not yet available.
