Wireless Transmission
Unleash Wireless Possibilities
  • 0.07s Low Latency
    0.07s
    Low Latency
  • 450ft (150m) LOS Range
    450ft(150m)
    LOS Range
  • 12Mbps Data Rate
    12Mbps
    Data Rate
  • SDI & HDMI Dual Ports
    SDI & HDMI
    Dual Ports
  • Flexible Monitoring Options
    Flexible Monitoring
    Options
  • Smart Channel Scan
    Smart Channel
    Scan
  • Multiple Fan Modes
    Multiple Fan
    Modes
  • Integrated Cold Shoe
    Integrated
    Cold Shoe
Transcending Limits
Transcending
Limits
Greater Range, Lower Latency
Mars 400S Pro II is a powerful video transmission device with several remarkable features. It offers a transmission range of up to 450ft (150m) and achieves a low latency of just 70ms. Additionally, Mars 400S Pro II is equipped with SDI+HDMI dual interfaces, supports multi-receiver setups, and allows monitoring through the HollyView App.
Experience Crisp Clarity with
12 Mbps Data Rate
8M
12M
Supports 12 Mbps data rate, enabling high-definition video transmission and delivering clear, refined image quality with rich details.
70ms Ultra-Low Latency
450ft (150m)
Transmission Range
Range: Feet
Latency: ms
100
450
70
50ft
Transmission Range
30%
Latency
Mars 400S Pro II raises the bar with an incredibly low latency of just 70ms. It outperforms Mars 400S Pro by reducing latency by 30% and providing a stable signal transmission range of up to 450ft. This ensures exceptional high-definition image quality and an immersive low-latency experience.
Furthermore, Mars 400S Pro II is compatible with Mars 400S Pro, allowing them to be paired and used together.
Note: The LOS range of 450ft (150m) is based on interference-free laboratory measurements.
just 70ms
SDI + HDMI Dual Ports for
Unmatched Compatibility
Unmatched Compatibility Unmatched Compatibility
Equipped with both SDI and HDMI interfaces, Mars 400S Pro II provides enhanced device compatibility and convenient connections to various types of equipment. Whether it's a DSLR camera or a professional film camera, Mars 400S Pro II can fulfill your connectivity requirements.
Steady Shooting with
Smart Channel Scan
Upon startup, Mars 400S Pro II automatically selects the best frequency channels. Additionally, channel scanning can be conducted using the receiver or the HollyView App, providing a visual representation of signal interference levels at each frequency. Allows for the swift identification of the most suitable frequency.
Smart Channel Scan
Note: Smart channel scanning with HollyView App
Monitoring on Up to
4 Devices
Mars 400S Pro II offers flexible solutions to meet monitoring needs, including team collaboration, multi-crew monitoring, and multi-member cooperation.
1 Transmitter X 2 Receivers
1 Transmitter X 1 Receiver & 2 APP
1 Transmitter X 4 APP
Monitoring on Up to 4 Devices
Download HollyView
Flexible Fan Control
Including Mute Option
Mars 400S Pro II is equipped with a three-speed fan adjustment feature (Auto, Low Speed, Off). Its intelligent cooling design allows it to perform optimally in various usage scenarios by reducing device temperature and ensuring stable signal transmission.
Auto Mode
The device automatically adjusts the fan speed based on its temperature, ensuring effective heat dissipation.
Low-Speed Mode
The fan operates at the lowest speed, reducing noise generation. This mode is suitable for environments where low noise levels are required.
Off Mode
The fan is completely turned off, making it suitable for scenarios that require absolute silence.
Integrated Cold
Shoe for Seamless
Installation
Integrated with a cold shoe featuring a 1/4-inch threaded cold shoe simplifies the installation process. Simply connect the cold shoe of the Mars 400S Pro II to the cold shoe slot on the device, without the need for any cumbersome additional installation steps.
Integrated Cold Shoe for Seamless Installation
Packing List
Transmitter
Transmitter x1
Receiver
Receiver x1
Antenna
Antenna x5
DC Adapter
DC Adapter x1
User Manual
User Manual x1
Warranty Card
Warranty Card x1
Mars 400S Pro II RX
Receiver
Receiver x1
Antenna
Antenna x3
DC Adapter
DC Adapter x1
User Manual
User Manual x1
Warranty Card
Warranty Card x1
Specifications
Interfaces
HDMI Input (Type A Female)
SDI Input
2* Antenna Interfaces (RP-SMA Male)
DC Input
USB Type-C
Supply Interfaces
DC Power Input: 6-16V
USB Type-C Power Supply: 5V/2A
Battery Power Supply: 6-16V DC
Power Consumption
<11W
Weight
206g
Dimension
(L*W*H): 110*72*33.5mm
(The Battery Plate Exclude)
Input
Video Format
HDMI:
720p50/59.94/60
1080i50/59.94/60
1080p23.98/24/25/29.97/30
1080p50/59.94/60
SDI:
1080p60/59.94/50(Level A)
1080p60/59.94/50(Level B)
1080i60/59.94/50
1080p30/29.97/25/24/23.98
1080psf24/23.98
1080psf30/29.97/25
720p60/59.94/50
Frequency
5GHz
Transmission Power
≤21+/-1.5dBm
Receiver Sensitive
Transmission Latency*
HD Mode: 70ms
Focus: 56ms
Bandwidth
20MHz
Interfaces
HDMI Output (Type A Female)
SDI Output
DC Input
USB Type-C
Supply Interfaces
Power Consumption
<7W
Weight
206g
Dimension
Output
Video Format
HDMI:
720p50/60
1080i50/60
1080p24/25/30
1080p50/60
SDI:
1080p60/50(Level A)
1080i60/50
1080p30/25/24
1080psf24
720p60/50
Frequency
5GHz
Transmission Power
Receiver Sensitive
-80dBm
HD Mode: 70ms
Focus: 56ms
Bandwidth
20MHz
Note: The operating frequency and TX power vary by country and region. In some countries and regions, the 5.1GHz, 5.2GHz, and 5.8GHz frequency bands are prohibited, or the 5.1GHz and 5.2GHz frequency bands are only allowed for indoor use. Please refer to local laws and regulations for more information. * test data when 1080p60 signals are transmitted in a laboratory environment.
