New Product Coming
DAYS
HRS
MINS
SECS
8 Best Lavalier Microphones in 2024
Lavalier microphones are incredibly small mics that pin to a person’s clothing and provide direct input to a wireless transmitter or sound recorder. Also known as body mics, lapel mics, or collar mics, these tiny devices are easily disguised or hidden, and we’re sure you’ve spotted one on your favorite TV show host at some point.
A good lavalier microphone is discreet enough to be almost invisible, making it a great fit for audio and video podcasters, and film and TV work. For this guide, we’ve reviewed some of the best lavalier microphones for every budget. From beginner-grade models to high-end devices, our list is extremely inclusive, so you can easily find the mic that best suits your needs and price range.
Whether you’re acting on a film set or recording an interview for YouTube, there are several instances where you may need a well-hidden and portable microphone. Luckily, lavalier microphones have an incredibly flexible and portable design, making them perfect for this job.
These devices are extremely easy to use, as you simply need to clip the mic to your clothes or tape it directly on your screen. However, it’s important to note that each model differs in its intended purpose, price, and design.
To help you navigate through the myriad of options, we’ve reviewed 8 of the best lavalier microphones available today, so you can easily opt for the one that seamlessly fits both your budget and your needs.
TitleLark MAXDJI Mic 2RODE Wireless ProSennheiser XS Lav USB-CRODE SmartLav+SYNCO P1L WirelessSennheiser MKE 2Shure MVL
Maximum SPL128dB120dB123.5dB110dB110dB125dB142dB124dB
Connector Type3.5mm audio jack, USB Type-C3.5mm TRS, Lightning, USB-C USB Type-CUSBTRRS3.55mm jack, USB3.5mm connector3.5mm jack
Compatible DevicesCamcorder, Smartphone, Laptop, CameraComputers, Tablets, Smartphones, CamerasComputers, Smartphones, CamerasSmartphones, ComputersSmartphonesSmartphones, Tablets, Lightning DevicesTransmitters with 7.5V supplySmartphones, Computers, Tablets, Headphones
Polar PatternOmnidirectionalOmnidirectionalOmnidirectionalOmnidirectionalOmnidirectionalOmnidirectionalOmnidirectionalOmnidirectional
Transmission Range820ft250m260m150m
Battery Life22 hours8 hours7 hours5 hours
WirelessYesYesYesNoNoYesNoNo
Price$249$349$399$59.95$51.50$69.98$390$86
The 8 Best Lavalier Microphones in 2024
Editor’s Choice: Lark MAX
  • Price: $249
  • Maximum SPL: 128dB
  • Connector Type: 3.5mm audio jack, USB Type-C
  • Compatible Devices: Camcorder, Smartphone, Laptop, Camera
  • Polar Pattern: Omnidirectional
  • Transmission Range: 820ft
  • Battery Life: 22 hours
  • Wireless: Yes
If you’re looking for a premium wireless lavalier microphone for your mobile filmmaking escapades, then you’ll be hard-pressed to find anything better than the Lark MAX. An all-in-one wireless system, this lavalier mic is designed with advanced ENC technology and MaxTimbre Mic technology, ensuring unrivaled, crystal-clear audio.
Hollyland LARK MAX
Learn More
The transmitter boasts an 8GB built-in memory and provides nearly 14 hours of backup recording, making the Lark MAX ideal for vlogging, electronic field production, interviewing, online teaching, podcasting, or any other audio recording applications that require a reliable audio backup solution and high-quality audio pickup.
Since the device is implemented with internal audio recording, you don’t need to worry about any audio cuts, interruptions, or sudden recording stops. Even if such instances happen, the device securely stores the audio within itself, ensuring the audio isn’t lost.
The microphone’s Environmental Noise Cancellation (ENC) technology further detects and minimizes ambient noise, ensuring distortion-free and crystal-clear audio even in loud and noisy recording environments. The Lark MAX is incredibly user-friendly as well, enabling you to quickly switch the ENC mode off or on using the transmitter or the receiver.
Lastly, unlike some other lavalier microphones, you don’t need to download an additional app to check the recorder or explore your audio files. Once you connect the microphone to your computer or phone, it will act as an external device, allowing you to retrieve your files directly and easily.
Pros
  • Solid and durable build quality.
  • Crystal-clear audio, even in busy, outdoor areas.
  • Easy to use.
  • Magnetic attachment points enable flexible placement.
  • Long battery life allows for all-day shooting.
Cons
  • Transmitter doesn’t have record-level buttons.
  • Shoe mount fit is a bit tight on some devices.
Best for Vloggers: DJI Mic 2
  • Price: $349
  • Maximum SPL: 120dB
  • Connector Type: 3.5mm TRS, Lightning, USB-C
  • Compatible Devices: Computers, Tablets, Smartphones, Cameras
  • Transmission Range: 250 meters
  • Battery Life: 18 hours
  • Wireless: Yes
The DJI Mic 2 is a solid, refined version of its predecessor, the DJI Mic 1, making it suitable for all kinds of content creators. Thanks to its noise-canceling technology, 32-bit float internal recording, and enhanced functionality, it deserves a place on our list of best lavalier microphones.
This microphone’s receiver is designed with a large touchscreen display and a physical control wheel, offering an intuitive user experience and allowing you to make quick adjustments as you record. Its strong transmitter magnets and ability to record both mono and stereo audio across all devices increase its versatility, enabling users to capture clear, crisp audio in a wide range of settings.
Furthermore, its updated charging case boasts a locking push button latch, enhancing both security and portability. Meanwhile, the reconfigured transmitter is designed in such a way that it prevents users from accidentally pressing buttons, ensuring nothing disrupts their recording.
All in all, the DJI Mic 2’s compatibility with various devices, refined noise canceling performance, and easy-to-use interface reinforce its position as one of the best lavalier microphones for streamers, YouTubers, and content creators, as it allows them to achieve professional-grade audio recordings.
Pros
  • Long-lasting battery.
  • Comes with several different accessories.
  • Exceptional wireless range.
  • Effective noise reduction.
  • 32-bit float internal recording and safety channel options.
  • Compatible with USB-C and Lightning cable ports.
Cons
  • A bit more expensive than other models.
  • Phone mounts might be a tight fit.
Best for Videographers: RODE Wireless Pro
  • Price: $399
  • Maximum SPL: 123.5 dB
  • Connector Type: USB Type-C
  • Compatible Devices: Computers, Smartphones, Cameras
  • Transmission Range: 260m
  • Battery Life: 7 hours
  • Wireless: Yes
The RODE Wireless Pro is an incredible piece of kit that’s much more than a simple lavalier mic. The box includes two Rode Lavalier II microphones, which you can pin to your clothes to record clear, crisp audio, or you can even record directly into the transmitters. Each transmitter boasts 32GB of internal storage, providing you with an infinite number of audio recording and storage options.
The included receiver is further compatible with a computer, DSLR, smartphone, recorder, and almost every other piece of equipment. The microphone also comes with magnetic transmitter attachments, a charging case, and “Intelligent GainAssist.” Once enabled, this feature will automatically alter and adjust your audio levels as you record.
It would be remiss of us to review the RODE Wireless Pro without mentioning its 32-bit floating technology. This functionality helps keep your audio distortion-free, enabling you to capture high-quality audio even when you’re facing sloppy gain settings or overly loud sounds.
However, it’s important to note that all these features will cost you a pretty penny. But if you consider all that you get, then the RODE Wireless Pro is definitely worth the money.
Pros
  • Comes with a charging case system.
  • Comes with two Rode Lavalier II extension microphones.
  • GainAssist technology helps ensure, clear, distortion-free audio.
Cons
  • Costly.
  • Accessories will need to be stored in a separate case.
Best for Beginners: Sennheiser XS Lav USB-C
  • Price: $59.95
  • Maximum SPL: 110dB
  • Compatible Devices: Smartphones, Computers
  • Transmission Range: –
  • Battery Life: –
  • Wireless: No
If you’re looking to purchase your first lavalier microphone, then the Sennheiser XS Lav is a great option. A relatively cheaper model, this mic is perfect for low-budget filmmakers, YouTubers, and other content creators who simply need a plug-and-play option.
The Sennheiser XS Lav is compatible with Windows, Android, iPadOS, and macOS devices. It’s incredibly easy to connect the mic to a USB-C device, and you can start recording your audio as soon as you plug it in.
The box also comes with everything you might need, including a foam windscreen, a carrying pouch, a microphone clip, and the microphone itself. If you don’t have a USB-C compatible device, don’t worry as the mic comes with a more conventional 3.5mm TRRS connector as well. If you’re an iPhone user, you can easily grab this version and use it with a 3.5mm Lightning connector.
The sound quality of the Sennheiser XS Lav is pretty impressive as well. However, if you’re a professional, then it might be better to opt for one of the more premium models on this list.
Pros
  • Good sound quality.
  • Sturdy and durable build.
  • Compatible with tablets, phones, and Windows computers.
  • Excellent value for money.
  • Low-profile design.
Cons
  • Lacks official iPhone support.
  • Only connects to USB-C devices.
Best for Podcasting: RODE SmartLav+
  • Price: $51.50
  • Connector Type: TRRS
  • Battery Life: –
  • Wireless: No
One of the best lavalier microphones for podcasters, the RODE SmartLav+ is filled with features and functions that make it a great option for YouTubers and content creators. Firstly, it boasts an incredibly compact and lightweight design, making it perfect for interviews or any other instances where you need the mic to stay hidden, but still be able to capture crystal-clear audio.
Secondly, the permanently polarized condenser mic has an omnidirectional polar pattern, ensuring an even sound capture from all directions. The mic’s impressive frequency range and signal-to-noise ratio further enable it to capture both high and low-pitched sounds with minimal background noise.
Moreover, with a maximum SPL of 110dB, this device can easily handle louder sounds without any audio distortion, making it perfect for YouTube recording and dynamic podcasting scenarios. The RODE SmartLav+ uses the power from your iPhone’s TRRS socket, completely eliminating the need for lugging around extra batteries.
It’s also important to note that this microphone works best when it’s used with the Rode Rec app. The SmartLav+ is even compatible with other audio recording applications that use a headphone jack, allowing you to play around with more advanced features and get the most out of your purchase.
Overall, whether you’re an established professional or a beginner looking to purchase your first lavalier microphone, the RODE SmartLav+ is an excellent choice.
Pros
  • Discreet and compact design
  • Comes with a 12-month warranty.
  • Rode Rec app makes it extremely easy to use.
  • Impressive sound quality for podcasts and YouTube videos.
Cons
  • Might pick up handling noise or clothing rustle.
  • Additional equipment is needed for wireless use.
Best Wireless Microphone: SYNCO P1L Wireless
  • Price: $69.98
  • Maximum SPL: 125dB
  • Connector Type: 3.55mm jack, USB
  • Compatible Devices: Smartphones, Tablets, Lightning Devices
  • Transmission Range: 150m
  • Battery Life: 5 hours
  • Wireless: Yes
The SYNCO P1L Wireless is an excellent lavalier microphone that sounds great and is extremely easy to use. The microphone measures around two inches and easily clips onto your clothes. Compatible with the latest iOS devices, it boasts a convenient plug-and-play operation and works from up to 150 meters away.
In terms of audio quality, the SYNCO P1L delivers a stunning sound performance, ensures crystal-clear audio, and offers a mid-range frequency that gives weight and presence to your voice.
The microphone offers a five-hour operation on a fully charged battery, and you can simply place it back in its case to charge it when it’s not in use. Lastly, this lavalier microphone can be plugged into the same phone or tablet you use to record your videos, making it perfect for all sorts of content creators. So, whether you’re live streaming or making YouTube videos and TikToks, the SYNCO P1L is the way to go.
Pros
  • Impressive sound quality.
  • Durable and solid build.
  • Comes with 9 vocal effects.
  • Extremely easy to set up.
  • Fast charging.
  • Long transmission range of up to 150m
Cons
  • Limited compatibility.
Best for Professional Performances: Sennheiser MKE 2
  • Price: $390
  • Maximum SPL: 142dB
  • Connector Type: 3.5mm connector
  • Compatible Devices: Transmitters with 7.5V supply
  • Battery Life: –
  • Wireless: No
The Sennheiser MKE 2 is the perfect option for those who have a larger budget and are looking for the best of the best lavalier microphone. This model comes with a sweat-protected umbrella diagram, so you can easily stick it onto your sweaty stage actors without worrying about any water damage.
Commonly used in TV sets and Broadway productions, the Sennheiser MKE 2’s omnidirectional polar pattern delivers an incredibly natural sound. It produces an extremely accurate frequency response and even allows you to tailor the response using the two sound inlet caps that come included with the model.
The microphone is designed with a reinforced stainless-steel cable and is available in several different connector options (XLR, open-end, or 3-pin jack). The MKE 2 also comes with a windshield, but you can remove it if you want to keep the mic completely hidden.
Pros
  • High-quality and durable construction.
  • Exceptional sound quality for instrument and speech applications.
  • Ideal for theater productions.
  • Umbrella-diaphragm protects the mic from sweat and moisture.
Cons
  • Expensive than other models.
  • Powered by EW series transmitters.
Best for iPhones and Tablets: Shure MVL
  • Price: $86
  • Maximum SPL: 124dB
  • Connector Type: 3.5mm jack
  • Compatible Devices: Smartphones, Computers, Tablets, Headphones
  • Battery Life: –
  • Wireless: No
One of the best microphones under $100, the Shure MVL offers tons of character, quality, and sound at a reasonable cost. The microphone gives weight to your voice and delivers a full, clear, and distinct result, making it perfect for lectures, films, and interviews.
It also boasts an impressive signal-to-noise ratio, while its 124dB SPL ensures distortion-free audio no matter how loud your environment is. It even comes with a clothing clip, a carrying pouch, and a windscreen for blocking our handling and wind noise.
Thanks to its design and functionality, the Shure MVL beautifully isolates your voice from noisy surroundings. However, this model specifically stands out to us because of its tailor-made specifications for iOS users. Since it’s an Apple MFi-certified model, it works seamlessly with any iOS device that has a Lightning connector, making it the top lavalier microphone for tablets and iPhones.
So, whether you’re podcasting, interviewing, or recording a heartfelt wedding speech on your iOS device, the Shure MVL is a reliable and solid piece of equipment that delivers exceptional audio quality, ease of use, and flexibility.
Pros
  • Apple MFi certified model seamlessly works with iOS devices.
  • Lightweight and compact design.
  • ShurePlus MOTIV app makes it easier to use.
  • Impressive midrange sound is ideal for almost all situations.
Cons
  • Might need additional adapters for some devices.
  • Need to download the Robe Central application for full functionality.
How Do I Choose the Best Lavalier Microphone?
Any of the aforementioned lavalier microphones will help enhance your project’s audio production values. However, before you make your purchase, make sure you consider your specific needs and purpose. In order to choose the best lavalier microphone, here are a few factors you should consider:
Sound Quality
The most important thing to consider when purchasing a lavalier microphone is its sound quality. Make sure you check the signal-to-noise ratio and frequency response of the model. It’s better to opt for a mic with a 20Hz to 20kHz or higher range.
Polar Pattern
Lavalier microphones usually come with cardioid or omnidirectional polar patterns. Omnidirectional mics capture sound evenly from every direction, while cardioid microphones reduce background noise by only focusing on the audio source in front of them. Make sure you choose a mic that best suits your purpose.
Wired or Wireless
Wired lavalier microphones are typically more budget-friendly and don’t require charging or batteries. On the other hand, wireless mics offer more flexibility and mobility, but are usually costlier and need power sources for both the receiver and the transmitter.
Battery Life
If you’re planning on purchasing a wireless lavalier microphone, make sure you factor in the battery life of the receiver and transmitter. It’s best to opt for a model that will last long enough for even your lengthiest recording sessions.
Compatibility
It’s best to purchase a mic that’s compatible with all your recording devices. Some models work better with certain recorders, smartphones, and cameras, so make sure you choose one that best suits your recording device.
Ease of Use
Some lavalier microphones have a plug-and-play operation, while others have a lengthier, more complex setup. Consider the time you’re going to spend on adjustments and setup and your technical expertise before making your purchase.
What are lavalier mics used for?
Lavalier microphones are great for close-up sound, as they’re able to capture high-quality audio that’s close to the source. For this reason, they’re ideal for interviews, TV sets, podcasts, or any other instance where you need to capture voice or dialogue.
Are there different kinds of lavalier mics?
There are wireless and wired lavalier mics. Wired models connect directly to a recording device and offer a reliable signal. On the other hand, wireless mics offer more mobility and freedom of movement, making them great for presentations and performances.
Lavalier microphones also differ in terms of their polar pattern, with directional mics focusing on capturing audio from one specific direction, and omnidirectional ones capturing sound from all directions.
Are there any drawbacks to using a lavalier microphone?
While lavalier mics are great, they may also capture unwanted noise, such as clothing rustle. Their small size can sometimes also result in poorer audio capture as compared to larger microphones. They’re sometimes visible as well, which may not be suitable for some video productions.
Do actors use lavalier microphones?
Even though you may not always see it, every actor usually has a small lavalier mic taped, sewn, clipped, or glued to some part of their hair, costume, or face. Having a microphone close by helps ensure crisp, crystal-clear audio and eliminates the problems associated with using distant mics.
Final Thoughts
After reading this review, you should be able to choose the best lavalier microphone for your needs. Whether you want the best microphone money can buy or are looking for something more budget-friendly, this list will have a model that will perfectly suit your purpose. Even if you opt for one of the lower-end options, we’re confident that it’s going to be one of the best lavalier microphones available in the market.
Facebook
Twitter
Pinterest
Related Posts
